2001 4runner Issue
Old Sep 7, 2008 | 07:30 AM
AirFoceOne's Avatar
2001 4runner Issue
So I had a check engine light pop because of my traction control. It pops every once in a while when I hit a bump. I wanted to reset the light because I was doing a 5 hour drive so I disco'd my battery and then reconnected it to clear the CEL. About 30 minutes into the drive I realized that my turn signals and horn did not work. I noticed because the turn signal indicators on the dash did not work. Both front and back bulbs are inop. I also noticed my front right turn signal is burnt out. I'm going to get a new bulb for the front right but that wouldnt be causing the all the other ones not to work right? I'm guessing its a fuse. Do any of you have a fuse diagram for a 2001 4runner v6 2wd.
Any help would be greatly appreciated.
Old Sep 7, 2008 | 07:40 AM
97ltd4x4's Avatar
Turn singnals and horn,Hmm almost sounds like something is going on in the steering column electrically.Pull the covers(3screws) and have a look,its worth a chance...Possibly a loose connector,hence you hitting bumps and things not working.
I am not sure about the trac,unless there is a steering wheel angle sensor in the steering column as well.
Old Sep 7, 2008 | 08:21 AM
Spence1016's Avatar
the fuse would be in the box that is next to your left knee, theres a diagram on the back of the cover
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
smiley52
Jul 11, 2015 05:16 AM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
