01 tcase actuator
Old Sep 24, 2013 | 02:17 PM
whiskey79's Avatar
01 tcase actuator
4wd has not worked in about a year, really want to do some beach drivin so i figured i try to figure something out. Tried to pull tcase actuator but it wont budge. It will rotate a little but itried to pry it and hammer a little. Does the whole assembly come out or are you supposed to take it apart in place?
Old Sep 24, 2013 | 04:27 PM
yodafan93's Avatar
pretty sure my instructor said you have to take apart the tcase to get it out today. Im in a automotive program for toyota technicians, and am taking a manual transmission, transaxle, and drivetrains course. be sure you disconnect the battery as the actuator can still be activated even with the key in the off position. i can give ya a definite answer next week, because thats exactly what we're going to do; replace actuators.
Old Sep 25, 2013 | 02:58 PM
whiskey79's Avatar
Got the tcase actuator to operate manually. Now it is stuck in awd mode. Front driveshaft and cv shafts are turning with rear drive shaft. Cannot get center diff to lock in. Checked both switches on actuator both are good. Does the tcase actuator lock in center diff also? I hate this 4wd system. Friend of mine has similar 4runner and is a very good mechanic he has same problem, worked on it awhile and gave up.
Old Sep 25, 2013 | 03:12 PM
yodafan93's Avatar
do you mean the front differential?
ps, see if any of these links help.
https://www.yotatech.com/forums/f2/0...m-help-128924/
http://forum.ih8mud.com/95-gen-toyot...age-fixed.html
Old Sep 25, 2013 | 04:24 PM
whiskey79's Avatar
This 4wd system also has a center diff so you can either have awd (1 of 4 tires spinning front and rear center diff unlocked) or 4wd (2 of 4 tires spinning front and rear center diff locked)
TheBFA
Feb 15, 2020 06:55 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Boomer8404
Sep 24, 2015 01:12 PM
May-39
Sep 6, 2015 01:05 PM
