PO 441 "Evap Emissions Control" flow code. Anyone else running without the EVAP syste
Old Sep 23, 2013 | 07:59 AM
Austin Marr's Avatar
Hey guys tried posting this in the 3.4 swap section but I haven't gotten any responses so I'm hoping I get some input here.
1) Do you run a EVAP setup? if not have you gotten this code?
2) Has anyone ever got this code before? what did they do to fix it?
3) Has/will this cause the vehicle to fail an emissions test?
Finished my swap like a year ago now and the truck is running amazing and smooth. The motor and all according swap components are from a 1996 T100. So when I pulled this motor from the donor it didn't come equipped with a EVAP box or anything of the sort. Curious why my ECU is throwing a code for my evap emission control when I dont even have a evap set up. Question though, where the 3.slo canister is removed from and where that hard line from the fuel tank comes from that 90's up into the canister, what have you guys done to that hard line if you do or dont have a evap set up? I capped it off with a vacuum cap but whenever i refueled and loosened the gas cap, more pressure then my 3.slo had would come out of the gas tank so i just poked a little hole in the top of the vacuum cap that i put on the hard line to relieve that excess pressure. Would that be the cause of the code being thrown? anywhere else i should look to try and resolve this issue? thanks guys.
Old Sep 24, 2013 | 07:09 AM
The code verbatum is "Evaporative Emissions Control System Incorrect Purge Flow"
Doug4320
Mar 24, 2018 10:11 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
timmJ
Jul 7, 2015 02:01 PM
