Is my transmission gone?
Old Sep 28, 2013 | 05:25 PM
bak3rme's Avatar
CEL code PO770 (shift solenoid E malfunction)
So guys is my transmission gone or is it even my transmission? any words of wisdom will help
long story short, I think I overfilled my transmission fluid by a lot and drove it with it overfilled for 2-3 months.
been noticing slipping for the past month, it slowly got worst..but was definitely still drive-able.
Yesterday I put the car in Reverse and backed out...but the car had a really hard time going in reverse. When I put it to Drive, I noticed it wouldn't budge, but I had to pump the gas a bit for it to get going.
Ever since then, its been pretty rough...stop lights take a lot of gas to get going (pumping the pedal, or else it just makes loud noises at high RPMs). Rolling on highway at 70 i dont notice much, but stop and go traffic hurts.
I cannot reverse the car, I will put in reverse and it will either stand still or it will drive FORWARD. Neutral gear does the same thing.
PO770 code came on a while ago. (shift solenoid E malfunction)
is this a part I can replace???
Thanks guys
Old Sep 29, 2013 | 05:21 PM
chadsy's Avatar
yes, you can replace the solenoid.
it is accessible through the trans pan.
Looks like they go for about 165 on rock auto.
Old Sep 29, 2013 | 09:24 PM
tantacoma's Avatar
According to my 1999 FSM, that code could also mean a bad valve body, or bad torque converter. Hopefully it just the solenoid. There is a test for the solenoid to see if its bad, once its removed.
Old Sep 30, 2013 | 02:52 AM
pat24's Avatar
what year is your truck and how many miles on it what did your fluid look like/ smell like
Old Sep 30, 2013 | 04:07 AM
UKrunner's Avatar
I don't think it's your torque converter. Is suggest solenoid or wiring loom.
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
