Input from seasoned Tacoma gurus.
Old Sep 27, 2013 | 04:08 PM
crafthorse's Avatar
2002 Tacoma with 3.4 liter. 167000 odd miles. Che k engine light came on the other day so I narrowed a friends OBD scanner. Its a Acton CP9135. It is showing 3 codes.
P0100 MAF or VAF circuit malfunction
P0110 IAT sensor circuit malfunction
P0442 EVAP emission system leak (small)
I know I will probably have to look at some hoses for the evap system, but was wondering if anyone else has ran into the other problems and what did you do to troubleshot or what had to be done to correct the problems. Thanks in advance for any help.
Old Sep 28, 2013 | 06:58 AM
87blackbeauty's Avatar
Not sure about the relationship to your vehicle, but many other vehicles will throw codes for EVAP if your gas cap is not on correctly. Everything from a Ford to a BMW will, so I figure a Toyota will.
Old Sep 28, 2013 | 07:17 AM
tantacoma's Avatar
On my 2.7, the MAF sensor also provides the IAT sensor. Make sure that its plugged in properly. If it is, then remove and clean with MAF/electronic spray cleaner. Thats where I would start.
Old Sep 28, 2013 | 07:49 AM
crafthorse's Avatar
Just unplugged it and treated the plug with dielectric grease. I did learn it provided both functions. I am currently researching how to test the MAF so I can see if its going bad. Thanks guys. Still open for others to comment.
Old Sep 29, 2013 | 12:35 AM
wyoming9's Avatar
Red face
With these newer vehicles your really making things hard for your self not having the diagnostics section in the FSM and at least your own code reader
It makes trouble shooting so very much easier gives you a step by step guide to follow.
G-off
Dec 29, 2015 12:44 PM
EatChipsNow
Sep 9, 2015 01:25 AM
TOYROX
Sep 4, 2015 06:02 PM
matthew138
Sep 3, 2015 08:21 AM
jjrbus
Jul 27, 2015 11:06 PM
