More Differential drop?
Old Sep 3, 2004 | 07:37 PM
BajaRunner's Avatar
Right now my front end is quite high, and my CV boots are at some dangerous angles. I already have a 1" DD spacer on there. I was wondering if I could add another .5" maybe .25" to it already.
What problems would I run into If I added a larger DD spacer?
I was planning on buying a few washers an adding it with the RB spacer.
Here, once again of a pic of my CV boots:
Old Sep 4, 2004 | 07:44 AM
User 051420's Avatar
I'm 99% sure that some company was selling 1.5" spacers, so they should work. The only issue I see is the crossmember being in the way...give it a try!
Do you notice any CV vibrations? I have my SAW's up way toooo high, and I'm getting a terrible vibration.
Old Sep 4, 2004 | 01:14 PM
superjoe83's Avatar
i used the washer stack method when i did the taco, i undid the two front mounting bolts, and pulled the diff down as much as possible and spaced it out that amount, works fine for me
Old Sep 4, 2004 | 07:28 PM
BajaRunner's Avatar
I think im going to try that.
Just adding another .5" would be cool...or how ever much I can add w/o hitting my crossmember.
Old Jan 11, 2005 | 08:04 AM
GodwinAustin's Avatar
SC did you try this? how did it work out and what did you use to lower the diff more? how much lower were you able to go?
Old Jan 11, 2005 | 08:14 AM
payyourtoll's Avatar
his sig says 1.5" Diff Drop so I am curious to see what came of this too.
justdifferentials
14
Jun 11, 2017 08:36 PM
djpg2000
Sep 7, 2015 10:36 AM
Jwp1
Sep 6, 2015 11:03 AM
justdifferentials
Sep 5, 2015 06:52 PM
