TPS help and Throttle Body Removing
Old Sep 5, 2004 | 10:15 AM
Rays94runner's Avatar
From everything I've read, I think I have a bad or malfunctioning TPS. Does anyone know any links for testing, possibly cleaning, and adjusting the TPS on a 3.0 engine. I really dont want to take it to a stealership. I know it involves an ohm meter. I also am interested in removing the Throttle body and cleaning it. Is this difficult? Thanks in advance for advice. Ray
Old Sep 5, 2004 | 10:22 AM
Yoter's Avatar
Guest
Ray, This write up says its for the 3.4 but I would assume its the same cleaning idea.
https://www.yotatech.com/~corey/tech...b/haveblue.htm
Old Sep 7, 2004 | 05:30 AM
I really want to remove it though and I still need some TPS(throttle positioning sensor) advice
Old Sep 7, 2004 | 07:39 AM
jht3's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Sep 7, 2004 | 04:30 PM
Goldrunner's Avatar
The TB is easy to remove, and you dont have to drain your radiator like is says in the hayns manual, just plug the hose(you'll know which one). The above site at 4crawler is the one I used to adjust my TPS, gives a great rundown on how to do it, I did find it much easier to adjust with the TB off the truck. You will need a new TB gasket, autozone usually has em if you dont want to visit the stealership.
Old Sep 8, 2004 | 07:31 PM
thanks, ill let u know how it goes, i think the tps is the cause of my rough idle and engine light, what u u8se to plug the hoses?
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
jetpilot
Aug 15, 2015 06:48 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
