Swaping Air intake and Battery places - 22RE?
Old 09-03-2004, 04:54 PM
YotaTruck1986's Avatar
Question Swaping Air intake and Battery places - 22RE?
I plan to swap the air intake location with the battery, and put the battery where the stock intake was, but i have one question. The cable that connects to the Air Flow sensor is to short to reach to the other side. What do I do? Thanks.
Old 09-03-2004, 09:42 PM
MNBOY's Avatar
I'm just going to cut mine and splice in some wires to lengthen it.
Old 09-04-2004, 04:41 AM
So, Just sticking in some copper wire will do the trick?
They have a tech article here on doing this project but it doesnt talk at all about lengthning the cable.
Old 09-04-2004, 06:49 AM
MNBOY's Avatar
The biggest problem is that it is a lot of wires, 10 or 12 if I remember right, so you have to keep track of them all, but I think it's really light wiring. If you've got a decent junk yard around there just get an extra one from them and cut it with as much wire as possible, then splice that into the original harness.
Old 09-04-2004, 07:55 AM
kevin444's Avatar
Dont you need to worry about signal degradation? Because of longer wires?
Old 09-06-2004, 03:39 AM
HiLux_1990's Avatar
Given this mod has been done before I would suggest that voltage drop is of little concern.
If you are worried though, you could re-wire the whole length to the sensor with larger gauge wire.
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
jon.r
07-11-2015 03:34 PM
Huntingtruckcletus
07-08-2015 05:26 PM
skoti89
07-08-2015 12:05 AM
Quick Reply: Swaping Air intake and Battery places - 22RE?
