Swaping Air intake and Battery places - 22RE?
Old Sep 3, 2004 | 04:54 PM
YotaTruck1986's Avatar
Question Swaping Air intake and Battery places - 22RE?
I plan to swap the air intake location with the battery, and put the battery where the stock intake was, but i have one question. The cable that connects to the Air Flow sensor is to short to reach to the other side. What do I do? Thanks.
Old Sep 3, 2004 | 09:42 PM
MNBOY's Avatar
I'm just going to cut mine and splice in some wires to lengthen it.
Old Sep 4, 2004 | 04:41 AM
So, Just sticking in some copper wire will do the trick?
They have a tech article here on doing this project but it doesnt talk at all about lengthning the cable.
Old Sep 4, 2004 | 06:49 AM
MNBOY's Avatar
The biggest problem is that it is a lot of wires, 10 or 12 if I remember right, so you have to keep track of them all, but I think it's really light wiring. If you've got a decent junk yard around there just get an extra one from them and cut it with as much wire as possible, then splice that into the original harness.
Old Sep 4, 2004 | 07:55 AM
kevin444's Avatar
Dont you need to worry about signal degradation? Because of longer wires?
Old Sep 6, 2004 | 03:39 AM
HiLux_1990's Avatar
Given this mod has been done before I would suggest that voltage drop is of little concern.
If you are worried though, you could re-wire the whole length to the sensor with larger gauge wire.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
jon.r
Jul 11, 2015 03:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
