Swaping Air intake and Battery places - 22RE?
I plan to swap the air intake location with the battery, and put the battery where the stock intake was, but i have one question. The cable that connects to the Air Flow sensor is to short to reach to the other side. What do I do? Thanks.
Originally Posted by MNBOY
I'm just going to cut mine and splice in some wires to lengthen it.
They have a tech article here on doing this project but it doesnt talk at all about lengthning the cable. |
So, Just sticking in some copper wire will do the trick?
Dont you need to worry about signal degradation? Because of longer wires?
If you are worried though, you could re-wire the whole length to the sensor with larger gauge wire. |
