22re intake
Old Aug 30, 2004 | 11:12 PM
desert whomper's Avatar
22re intake
can i see pics of ppl that have either stock or modified air intake systems on 22re's, thx
Old Aug 31, 2004 | 12:27 AM
Zetoe's Avatar
I put a generic K&N on my 22re. Just removed the stock intake box and replaced it with the cone filter.
I've been wanting to switch the filter with the batt so the intake doesn't have to cut across the rad, but I have yet to do that. In my short research back when I looked this up I recall somebody had done it and said it was quite easy, as all the mount points are there.
Anyways, HTH
Old Aug 31, 2004 | 04:48 AM
PirateFins's Avatar
Try using the search there is alot of info out there.
This thread I am linking is a good place to start. Both Eway and I have done about the same thing. Have fun!
https://www.yotatech.com/forums/f2/22re-airbox-mod-writeup-please-38727/
Old Aug 31, 2004 | 04:06 PM
whats the box do right before the air filter, i know it has a little lever that allows a certian amount of air in, is it like an electronic choke?
Old Aug 31, 2004 | 04:07 PM
AzStorm's Avatar
Its a mass air flow sensor that adjusts the air fuel mixture via the computer when driving at freeway speeds I believe.
Old Aug 31, 2004 | 04:10 PM
so if i eventually do the ECT mod it will affect this piece and thus tell the coomputer to advance the timing? i think thats what i mean.
Old Aug 31, 2004 | 05:02 PM
AzStorm's Avatar
yup
it all works together as a system
Old Sep 1, 2004 | 02:13 AM
Tokez420's Avatar
did u just plug that hose with something? or what did u do?
Old Sep 2, 2004 | 01:42 AM
Zetoe's Avatar
It's a generic crankcase filter breather. I didn't want it sucking in huge particles... but I'm too cheap to get the trick air filter for it.
BTW, this is not CARB legal so I have to change it back to the airbox in order to pass smog.
Old Sep 2, 2004 | 11:37 AM
Tokez420's Avatar
thanx
i did the same thing. u know where that hose leads to? what is it and what does it do?
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
