2000 sr5 v6 & 2004 sr5 v6 Headers?
Old Sep 1, 2004 | 11:11 AM
grunvs1's Avatar
Question 2000 sr5 v6 & 2004 sr5 v6 Headers?
Will headers for a 2000 tacoma sr5V6 fit on a 2004 sr5V6? Are the engines
still the same? Found a good deal on a set, but not sure if they will work.
Good deal may not last long. Please respond ASAP.
Thanks
Old Sep 1, 2004 | 11:18 AM
rimpainter.com's Avatar
If the engine code is 5VZ-FE on both rigs, the "donor" rig has the same transmission and height (no BL, etc) then the headers will cross over (or should I say under )
You may also want to check on the cat situation. I believe they are both single cats unless you are in Cali.
Jdgarrison
Oct 1, 2015 05:22 PM
sonorn67
Sep 19, 2015 05:39 PM
Gideon's Test
Mar 21, 2008 07:53 AM
swamprunner1
Jan 4, 2008 01:56 PM
jandk2005
Feb 21, 2006 01:32 PM
