setting tdc
Old Sep 7, 2004 | 12:01 PM
Jakub's Avatar
setting tdc
I have a carbed 84 w/ a 22r. How do you tell if the engine is on the compression or exhaust stroke without pulling the rocker arm cover off? When putting the head back on the distributor was put on wrong the first time so the car won't idle. I know on my mr2 you look in the oil fill hole and look at the cam lobes.
thanks,
Jakub
Old Sep 7, 2004 | 01:32 PM
Plays_with_Toys's Avatar
I imagine you can pull the plug and see if the piston is up top... Scroll down a bit, to "can't start my engine" thread by ScubaSteve, he just had to do the same thing, and I think it was explained in there.
Old Sep 7, 2004 | 09:43 PM
the_supernerd's Avatar
Try putting your finger over the spark plug hole and turn the engine. If you keep the hole sealed with your finger, you should be able to feel the compression against it on the compressions stroke.
1uzRunner
63
Nov 10, 2018 03:58 PM
fabing455
Sep 7, 2015 08:08 AM
