Which body lift accessories?
Fixing to order a 2" body lift from Roger Brown and I was going to purchase the shift level extension for the 4 wheel selector and extended brake lines. What else would be recommended to purchase to compliment this body lift?
Grade 8 hardware for sure.
Steering extension is required for 2"+.
You might want to raise the ARB front bumper, I did not on mine.
Remove the lower fan shroud.
Radiator lift brackets maybe.
And you will need to loosen several other connections so you don't pull something loose when installing the spacers such as the battery cables, etc.
I got the steering extension (a must), the bumper brackets (may or may not work for your ARB - no idea) I removed my lower fan shroud, and did not drop my rad. Because it gets hot where you are you may want to drop your radiator. Oh, and I wouldn't bother with the t-case extension, it's really not that low. And definetly go with the Grade 8 hardware, and the larger diameter lift pucks.
09-04-2015 09:27 AM
anniesball
07-29-2015 11:46 AM
