rims and tires
Old May 22, 2007 | 11:26 AM
haschen's Avatar
rims and tires
What do i need to know about my lug pattern (99 stock tacoma rim (15)) in order to shop for knew rims. I just got a 3inch lift and need larger tires but dont have the money to spend on nice rims. Cheap-o's are what im looking for. If i cant find cheap rims then im gonna have to get 31x10.50's. Does any company make a 32 or 33 10.50? thanks
Old May 22, 2007 | 01:40 PM
rathead's Avatar
You can definitely find some 33x10.5's out there, but you should be able to fit 32x11.5's on your stock 7 inch rims no problem. Some tire shops won't do it, but most will.
Check out tirerack.com for research means.
Your lug pattern is 6 on 5.5, very popular size, many aftermarket rims available as low as $35 ea. for 15x7 or 8 steelies.
Hope this helps.
Old May 28, 2007 | 05:34 PM
haschen's Avatar
where you find those rims for 35? thanks
Old May 28, 2007 | 05:41 PM
MillerPKA's Avatar
rockcrawlers go for 80 something apiece i think. i have them on mine and they work great. you could manage 255/85s on your stocks too i believe
Old May 28, 2007 | 05:57 PM
MAIDEN's Avatar
look for used rims on craigslist thats where i got mine..basically brand new black american racing rims for 100$... damn good deal!
Old May 28, 2007 | 08:21 PM
YM13's Avatar
Originally Posted by rathead
7 inch rims no problem...
Hope this helps.
hahaa nice...
Old May 28, 2007 | 08:34 PM
the_gunslinger's Avatar
6x5.5?? my '97 5runner doesn't think so...i haven't measured, but known 6x5.5 wheels didn't fit...
Old May 28, 2007 | 08:45 PM
HuskyRunner's Avatar
Yeah, the bolt pattern is 6x5.5" and you can definetly fit 255/85/16's (33.3"x10")
Old May 28, 2007 | 08:54 PM
rathead's Avatar
My bad, not $35 but $38 for some 15 x 7's, Check out Summitracing.com and search for cragar wheels. Your local wheel shop, e.g. Big'o'tires, Wheels Works or whatever should be able to get you a good deal on Cragar or Pacer (just like American Racing or Pro Comp) black steel rims.
I'd do like MAIDEN and check out Craigslist, not sure where you are located, but here in the Bay Area of CA Craigslist is always a good place to start.
Old May 28, 2007 | 11:35 PM
slus's Avatar
These wheels have got to be the easiest bolt pattern to find on earth. I have a side yard collection of wheels that I've run into for cheap/free and cant refuse. Sharing a bolt pattern with a million chevy trucks helps things...
Old May 29, 2007 | 12:03 AM
yea, i've got some 16x9's from an 80's gmc (aftermarket, of course) but the bolt pattern didn't line up...huh, i wonder why...
Old May 30, 2007 | 10:08 PM
rathead's Avatar
Chevy's bolt pattern is 6 on 5.5, American/SAE. Toyota's pattern, and Nissan's, pre-ford Mazda's and anything else from Japan that uses 6 lugs, is also 6x5.5 in. but metric: 6x139.70mm
They should fit anyway however.
Old Jun 3, 2007 | 06:23 AM
haschen's Avatar
well i need some rims so if you hear of any hit me up thanks
Old Jun 3, 2007 | 08:52 AM
89macrunner's Avatar
where are you located I have a set of black cragar wheels i need to get out of my garage?
Old Jun 3, 2007 | 10:56 AM
haschen's Avatar
Easton MD, The Eastern Shore
chukarhunt
Dec 8, 2019 11:39 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
jpluddite
Oct 2, 2015 03:49 PM
sphealy
Sep 3, 2015 07:55 PM
Yotoder865
Jul 9, 2015 07:51 PM
