rims and tires
rims and tires
What do i need to know about my lug pattern (99 stock tacoma rim (15)) in order to shop for knew rims. I just got a 3inch lift and need larger tires but dont have the money to spend on nice rims. Cheap-o's are what im looking for. If i cant find cheap rims then im gonna have to get 31x10.50's. Does any company make a 32 or 33 10.50? thanks
You can definitely find some 33x10.5's out there, but you should be able to fit 32x11.5's on your stock 7 inch rims no problem. Some tire shops won't do it, but most will.
Check out tirerack.com for research means.
Your lug pattern is 6 on 5.5, very popular size, many aftermarket rims available as low as $35 ea. for 15x7 or 8 steelies.
Hope this helps.
Hope this helps.
My bad, not $35 but $38 for some 15 x 7's, Check out Summitracing.com and search for cragar wheels. Your local wheel shop, e.g. Big'o'tires, Wheels Works or whatever should be able to get you a good deal on Cragar or Pacer (just like American Racing or Pro Comp) black steel rims.
I'd do like MAIDEN and check out Craigslist, not sure where you are located, but here in the Bay Area of CA Craigslist is always a good place to start.
These wheels have got to be the easiest bolt pattern to find on earth. I have a side yard collection of wheels that I've run into for cheap/free and cant refuse. Sharing a bolt pattern with a million chevy trucks helps things...
yea, i've got some 16x9's from an 80's gmc (aftermarket, of course) but the bolt pattern didn't line up...huh, i wonder why...
Chevy's bolt pattern is 6 on 5.5, American/SAE. Toyota's pattern, and Nissan's, pre-ford Mazda's and anything else from Japan that uses 6 lugs, is also 6x5.5 in. but metric: 6x139.70mm
They should fit anyway however.
Jamie4runner2000
Jun 20, 2016 09:13 AM
FS[SouthEast]: 1992 4Runner with 3.4 5speed $2000
sphealy
Sep 3, 2015 07:55 PM
