Best way to fix rubbing?
Old May 29, 2007 | 08:38 PM
Texas_Ace's Avatar
Ok, i just installed some spacers (yes i know they suck, you don't have to tell me!) and now i get a slight bit of rubbing right at the rear corner of the fender well (not the firewall side but the plastic that is inside the fender).
It is just a little bit of rubbing but in reverse it just might catch and rip something off. What is the best way to fix that? cut it out?
2000 4runner stock hight and 265's only about a half inch of rubbing.
Old May 29, 2007 | 08:41 PM
MillerPKA's Avatar
trimming would be the way to go....but i don't understand....265s clear stock suspension without issue. i don't know why a spacer lift would compromise that....are we talking wheel spacers or coil spacers?
Old May 30, 2007 | 09:01 AM
Texas_Ace's Avatar
Whell spacers. And i thought it would still clear fine too but it just rubbs a little on this one spot. At full lock it gets past it and doesn't rub but at just a little from full lock it rubbs.
I will look at that when i get home.
Old May 30, 2007 | 02:00 PM
HuskyRunner's Avatar
Might be a silly question, but, why'd you put the spacers on to begin with? Just for looks? As for the rubbing, grab a utility knife and a hammer and go to town on it. Cut away the plastic piece, under that will be a piece of steel. Pound that flat and no more rubbing. Or take off the spacers.
Old May 30, 2007 | 02:05 PM
Texas_Ace's Avatar
Yeah, they are just for looks. And i am VERY happy with the new look. It looks much more aggressive now. I wanted to get some new rims but could not get the $$ so i had to settle with the spacers.
I will cut it up tonight, i didn't know if there was a magic way to do it without cutting but i will get that done either way!
Old May 30, 2007 | 02:11 PM
Well, the other way would be a body lift. Avoids cutting all together. Relatively cheap, and will make your truck look taller, as well as clear the tires.
Old May 30, 2007 | 02:51 PM
MillerPKA's Avatar
husky knows all about that body lift haha, his is damn sexy
1" would completely rid you of your trouble, but if you're taking the trimming route a grinder works well, get a finer, smaller head to consolidate the trimming areas, meaning you don't accidentally trim more than you want. then brush up with a sander and it should be good to go
Jamie4runner2000
Jun 20, 2016 09:13 AM
altydog
Aug 30, 2015 06:44 AM
upongame619
Aug 1, 2015 12:12 AM
kvanzandt1
Jul 18, 2015 10:15 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
