panhard bar?
Old May 26, 2007 | 11:26 AM
roadking8633's Avatar
Talking panhard bar?
I recentlt bought a 2000 4runner and since it needs new shocks and tires i decide to put a 3" toytec lift on it. i am not a hardcore wheeler. my question is about the pan hard bar. is it better to replace with a new one or to modify the one i have? or maybe a adjustable one? just looking for options and links to places i can purchase such things. thanks.
Old May 26, 2007 | 11:30 AM
TRDrunner's Avatar
sonoran steel has an adjustable one.
it goes from stock to 6 inches of lift i think?
www.sonoransteel.com
Old May 26, 2007 | 11:38 AM
weiln's Avatar
You shouldn't need it. I just put the OME 890's on the rear of my 2000 4Runner, can't even tell the axle moved.
Save your money for something else.
Old May 28, 2007 | 06:22 PM
j-man's Avatar
i put the ome 891's on the rear and got a full 3" of lift and every time id hit a bump, it felt like the rear was taking a jump to the other side. Now that i have the sonoran steel adjustable pan hard bar, i adjusted it to specified length, and now the rear tracks straight after i go over bumps. Some say they dont need it, but mine was real squirely without it. go for it.
Old May 28, 2007 | 08:18 PM
TX-BLKRUNNER's Avatar
Yeah I have the sonoran steel adjustable trac bar, and it's awsome, i was experiencing some of the above mentioned, that bar fixed it, not to mention my bushings in the stock bar were worn out, and it was clunking like crazy, so i opted for the SS bar and am very pleased, i think they run $175
Old Jun 8, 2007 | 06:43 PM
does anyone know if there is a weld in adjuster for the4runner panhard bar? i remember seeing one for jeeps.
Old Jun 8, 2007 | 11:19 PM
btruong1's Avatar
You mean like just an panhard bar bracket adjuster? like this?
http://www.sonoransteel.com/store_drop_bracket.html
Old Jun 9, 2007 | 08:11 AM
no, i mean a threaded adjuster thta goes in the middle. you cut the bar in half and then weld in the adjuster. i remember seeing one in a jeep mag somewhere. i am just not sure what the inside diameter is of the 4runner panhard bar and if there is a weld in that will fit.
ladybugRC
458
Aug 21, 2020 10:41 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
potatopants
Sep 15, 2015 06:26 AM
mdh
Sep 15, 2015 12:12 AM
