Noise in Front end While Turning Left/ Clicking while going straight.
Well after solving the squealing brakes that I had for a while, It seems like the quietness helped me hear a few things that I couldn't hear while driving before. I have a bad grinding,clicking,popping sound coming from (what i think) the passenger side front wheel. I figured I had messed something up when I replaced the brakes because I dont remember hearing/feeling anything like this before I did the brakes. I checked to make sure I had re installed correctly and everything seems fine (brakewise). I did search and I think my culprit is the drivers side CV joint since it only happens when I'm turning left at a slow speed. I jacked up the tire to see if i could recreate the sound while just spinning the wheel and all I hear is the brakes lightly rubbing. I also pushed and pulled on the wheel and there is no play or rattle so I know it is not the bearings. Has anyone ever had a problem like this?
A second noise has also developed since the brake upgrade... its a ticking noise that varies with speed.. i can't hear where its coming from or what side its from but I suspect that it is the same wheel area as the other problem.. they may even be related so hopefully when I fix/replace the parts both will be gone.
So in a nutshell, Is there anything in the brake components that would cause this sort of noise? Do CVs click when they are broken? What do you think my noise is coming from?
Please help diagnose this as it is Sunday and there are no mechanics open on Sunday... like cars don't brake down on a Sunday.
Also, to make things even more complicated... If I turn the wheel ALL the way to the left, there is no noise. ::Edit:: I just had a friend drive around in circles for me and you CAN hear when the wheel is turned completely from the outside, just not the inside.
Funny story actually.... I searched for clicking while turning and grinding and saw that the majority of the answers were about CV joints. Well then I assumed I had CV joints, period... which now, after thinkin outloud on this post for a while... i realize that SINCE it is a 2WD there are no CV joints... so now the question has changed... what could cause these noises in the fron end of a 2WD?
ADD= automatic disconnecting differential....but since you dont have 4x4, you dont have that. If you have aftermarket rims, they could be rubbing something at full lock?!
222,221 miles, but I dont have 4wd so there are no CV joints...Im going to check the stabilizer in the morning, anything else that could cause this sort of clunking or ticking whilst turning. Whilst.. when does anyone ever say that anymore.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
toyoda8488
Jul 5, 2015 10:18 PM
