time to change timing belt, parts list help please !
besides the timing belt and water pump i have the idler roller bearing, tensioner bearing, hyydraulic tensioner, camshaft seals X2, front crankshaft seal. any other parts you guys think i should replace while i'm in there? thanks
Might help if you list your vehicle and motor in the future or put it in your sig.
Numerous threads with parts list found in a search of "timing belt parts list"
'98 3.4 Automatic w/ 123k miles, getting a new; Timing Belt, Waterpump, Timing Belt Tensioner, Tensioner Pulley, Idler Pulley, Crank Bolt, Cam and Crank Seals. I'll have it in a few weeks. My truck makes a really annoying humming/whining sound and I've got a feeling it's that. Might be needing a new alternator here soon too.
Just finished changing mine out this past weekend, runs so much better.
My biggest problem was getting the crankshaft pulley off... I finally figured if you pull off the plate on the tranny that exposes the flywheel and wedge an allen wrench (the bigger the better) in there you can torque on it without it turning.
And another small tip, invest in some mechanix gloves i tore my hands up without them...
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
WI Girl
Jun 25, 2015 03:45 AM
