time to change timing belt, parts list help please !
Old Mar 3, 2010 | 12:44 PM
kennyb3030's Avatar
besides the timing belt and water pump i have the idler roller bearing, tensioner bearing, hyydraulic tensioner, camshaft seals X2, front crankshaft seal. any other parts you guys think i should replace while i'm in there? thanks
Old Mar 3, 2010 | 12:47 PM
waskillywabbit's Avatar
Might help if you list your vehicle and motor in the future or put it in your sig.
Numerous threads with parts list found in a search of "timing belt parts list"
Old Mar 3, 2010 | 12:55 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
Seems like 1 a week (though I keep answering them...)
Old Mar 3, 2010 | 01:02 PM
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Old Mar 3, 2010 | 02:44 PM
TheDurk's Avatar
3 accessory belts and thermostat, unless done in recent past. Don't forget coolant.
Old Mar 3, 2010 | 09:57 PM
CodyX36's Avatar
'98 3.4 Automatic w/ 123k miles, getting a new; Timing Belt, Waterpump, Timing Belt Tensioner, Tensioner Pulley, Idler Pulley, Crank Bolt, Cam and Crank Seals. I'll have it in a few weeks. My truck makes a really annoying humming/whining sound and I've got a feeling it's that. Might be needing a new alternator here soon too.
Old Mar 4, 2010 | 01:17 AM
dgl4runner's Avatar
Just finished changing mine out this past weekend, runs so much better.
My biggest problem was getting the crankshaft pulley off... I finally figured if you pull off the plate on the tranny that exposes the flywheel and wedge an allen wrench (the bigger the better) in there you can torque on it without it turning.
And another small tip, invest in some mechanix gloves i tore my hands up without them...
Old Mar 4, 2010 | 07:54 AM
kennyb3030's Avatar
already had the accessory belts changed at 110k, now im at 135k, gona get the timing belt etc done at 145k-150k ! thanks for the help guys
Old Mar 6, 2010 | 01:06 AM
wyoming9's Avatar
Red face
i am rather clumsy so I make sure to have extra timing cover bolts or any other special bolts that i will lose at the worst possible time.
vasinvictor
Jan 20, 2016 12:39 PM
layifioren
10
Jul 6, 2015 02:26 PM
WI Girl
Jun 25, 2015 03:45 AM
abalagtas
Jun 22, 2015 12:57 PM
stretch786
Aug 3, 2005 02:17 PM
