98 3.4l automatic. died when reversing
Old Oct 23, 2017 | 06:22 PM
Steve Mcnaught's Avatar
Earlier today when I was backing out of a parking space, I turned the wheel fully to the left and the truck bogged down and died. I put it in neutral started back up, drove to work no issues. When I left work, started truck put in reverse, it started cutting out, I through it back in neutral rpms went back up, gave it a little gas, put in reverse, back out and drove home fine, my idle did drop to 500 rpm when I was in my driveway, but it did not die
I cleaned my throttle body, and my mass air flow, like 2 weeks ago, haven't had any issues till today. Is this a air control valve issue or what.
There was no CEL either.
Old Oct 24, 2017 | 12:13 PM
Update
Started this morning drove to work no issues. Swung by AutoZone check for codes, nothing. So a couple of things I am leaning towards. A dirty idle air control valve, since I didn't clean it when I cleaned the throttle, or vacuum leak, (IAC). Thoughts?
Old Oct 28, 2017 | 07:36 PM
vital22re's Avatar
totally a bro
More than likely its the idle air control valve. I've had to replace a few on the 3.4's. You should also have a power steering idle up valve near your power steering pump on the pressure line. Make sure its plugged in (98 should be electric) or hoses connected (97 and earlier)
Old Oct 28, 2017 | 09:21 PM
Update
I scrubbed my IAC it was pretty chunky. Everything seems good for now, I will check my power steering
