99 4Runner,new motor acc belt won't Line up
I have a 99 4Runner 4x4. Motor blew so I picked up another 3.4 but I'm not sure what the motor originally came out of. I had to change motor mounts,exh. Manifolds, throttle body. I used all the accessories off the 4 runner and changed the damper pulley on the crank. None of my accessories line up. My belts squeak and it burns through them fast. It looks like the water pump sticks out an 1/8- 3/16" to far. Is there a long shaft /short shaft water pump?. also look like the ac compressor is out a little to far also but the bracket I think will only bolt on one way?? Thanks for any help
I'm not sure if the dampers are different. All the pulleys were offset different. I know the water pump is behind the black plastic cover. I guess I thought the part sticking out right in the middle of the motor/in the front middle of the motor was part of the water pump. It has two pulleys and the fan bolts to it. This is the part that sticks out further. Thank you!
When you say exhaust manifold and mounts needed changing that is a red flag that most likely this is a JDM, a lot of JDM's don't have the over the top of the bell housing crossover pipe, motor mounts being different is a major concern. BUT you should have no issues with Acc belts as they all came on the motor aligned from factory with there components, but JDM motors get shipped in containers with little care and roll around in storage for god knows how long, it is very likely the attached components took a hit either because of an accident before removal, or during shipping, storage or install, all your old components should fit, but difficult to determine which is the culprit.
A lot of subjective descriptions...maybe some pictures of the problem areas would help clear things...
Changing something because they were worn? Or change as in different from what you have?
Wherever you got the replacement, are they able to track down what yr/model it came from?
