My Starter just clicks
Old Sep 17, 2017 | 12:26 PM
aldaman014's Avatar
Hello All,
I have a '96 Runner with the V6 (3.4L) engine and auto trans. The battery is fully charged and the Runner won't start. When attempting to start it, it just clicks. Does that mean I have to replace my starter. What else can I check?
Thanks in advance
Old Sep 17, 2017 | 12:34 PM
ksti's Avatar
How many volts is your battery showing?
Old Sep 17, 2017 | 12:58 PM
aldaman014's Avatar
Not sure, but I had it recharged at Oreillys Auto parts.
Old Sep 17, 2017 | 01:10 PM
ksti's Avatar
I hope they did a load test on that battery before and after they charged it.
A fully charged battery =12.6 volts.
Do you have a volt/ohm meter to check the voltage?
Old Sep 17, 2017 | 02:57 PM
habanero's Avatar
Also look into the possibility of worn contacts and plunger though that usually starts as intermittent. Write-up by Hrt4me in my build thread, there's write-ups on them in all sorts of places because it's pretty common.
Starting post #1609
https://www.yotatech.com/forums/f200...l#post52156519
Old Sep 24, 2017 | 07:52 PM
aldaman014's Avatar
Update..
I replaced the contacts and that didn't solve my clicking issue.
1) Had the starter tested after the rebuild at Oreillys and the person said it passed twice
2) Tested starter relay by using one from a working vehicle but that didn't help.
3) used a different battery from another working vehicle and that didn't help.
Could it be my starter ignition switch? Thanks.
Old Sep 25, 2017 | 04:09 AM
Noil's Avatar
Almost sounds like a bad ground or grounding issue. I would check make sure your grounds are in good shape.
Old Sep 25, 2017 | 08:31 AM
aldaman014's Avatar
ok, will check that out. Thanks.
Old Sep 25, 2017 | 07:57 PM
RAD4Runner's Avatar
In the video the solenoid sounds like it actuates energetically and most likely is closing the contact well.
Most likely root causes (assuming contacts were done right):
1) Poor connection to battery,
2) Weak battery.
3) Bad starter motor (winding or brushes).
Originally Posted by aldaman014
...Could it be my starter ignition switch? Thanks.
NO!
AND BEWARE OF BECK-ARNLEY IGNITION SWITCH: Ask me how I know:
https://www.yotatech.com/forums/f199...l#post52329329
Originally Posted by ksti
...A fully charged battery =12.6 volts. Do you have a volt/ohm meter to check the voltage?
+1 The voltmeter/multi-meter is the most important electrical troubleshooting tool, next only to our senses. Spend $6 at Harbor Freight or waste time guessing.
What voltage do you measure at the battery with everything off? With headlights on high-beam? A battery that has more than 10V with high-beams on should still be able to turn the starter motor, although weakly.
+1/2
Not just ground. Check ALL connections between battery and starter.
Check the thick cable that goes from battery positive to the screw-terminal on the starter/starter solenoid. Check the thick cable that goes from battery negative to (I believe) the block. All connections should have bare, shiny metal tightly touching bare, shiny metal. If either of the above connection is poor, starter solenoid would still click and contact will close but there would not be enough power to run the starter motor.
Old Oct 1, 2017 | 02:56 PM
aldaman014's Avatar
Thank you all for the advice / help. Found the culprit. It was a bad connection from the positive battery cable. It was all corroded by the terminal connection. Previously my son changed the terminal post and I never bothered to check the wires connected to it. I assumed he cleaned up all that area thoroughly. After inspecting it and cleaning the wires of all the corrosion, the Runner started right up with one turn of the key.
thanks....
Old Oct 1, 2017 | 04:39 PM
RAD4Runner's Avatar
Cool that you fixed it.
See? Toyota's are bulletproof. most problems are caused by poor connection, assembly and/or maintenance.
[QUOTE=aldaman014;52377212]... Does that mean I have to replace my starter.
... I replaced the contacts
Could it be my starter ignition switch? ..,.
