95.5 Headlights wont dim
Old Oct 29, 2017 | 03:41 PM
edmondsonknives's Avatar
SO I have a 95.5 tacoma 4x4 ext cab, Im in the process of getting it to looking new again and have run into a issue with the headlights. When I switch the lever to dim the lights they go off, so I only have high beams. Something weird is the High beam indicator stays on the dash even though i switch the switch to dim? I have checked the fuses, the headlight relay. My gut tells me the combintation switch but before I drop 200 on one I figured Id ask you guys, thanks tremendously for your help and advice!!!!
