95.5 won't start unless hit with starting fluid.
Old Oct 11, 2017 | 02:10 PM
cbrown67's Avatar
Having an issue with my sr5 v6 if it sits to long it will just crank and not Fire, if I spray some starting fluid in it just a little bit it'll fire right up and run and idle.
Old Oct 12, 2017 | 09:34 AM
75w90mantraN's Avatar
Intake leak? Too much air mixing in and interfering with the fuel it seems. Dirty meter/intake sensor perhaps?
Does it idle rough? Stall? Engine light come back on?
Could also be fuel pressure related...but I'd check for the above first.
