electric antenna
Old Nov 1, 2017 | 07:14 PM
ddankanyin's Avatar
electric antenna
1995 4runner sr5 cant get the antenna to re set--radio on antenna down-radio off-antenna up tried disconnecting battery, un plugging antenna motor etc. is there a simple way to reset this??
Old Nov 2, 2017 | 12:23 AM
wyoming9's Avatar
Red face
Depends just how you define simple .
Is there more of a story to this ??
How did this start ?
Anything new added to the mix?? Wiring or new goodies added ??
Just a guess but it seems the polarity of the antenna is reversed .
Since most auto antennas use a relay to control them you have some trouble shooting in your future .
Since every auto antenna to ever be in my reach never worked I never spent time trouble shooting them
Old Nov 2, 2017 | 05:45 AM
Malcolm99's Avatar
Does it make any noises, if so, Perhaps the little teeth on the plastic whip that pulls and pushes the antenna up and down is stripped, they are still available at Toyota when I changed mine 4 years ago, very easy fix if that is the case.
Old Nov 2, 2017 | 07:15 AM
ddankanyin's Avatar
It goes up and down just fine, but opposite of when it should-----turn the radio on it goes down; turn the truck off it goes up The plug cant be plugged in wrong it won't I do hear a click from behind the driver side dash, I need to investigate that further, but have to go to work now, Thanks, Doug
Old Nov 2, 2017 | 08:34 AM
akwheeler's Avatar
Stock stereo or aftermarket? how long have you had the truck and has it been doing this the whole time or just started one day?
Old Nov 2, 2017 | 01:14 PM
wyoming9's Avatar
Red face
Comes back To just How did this Start??
Old Nov 2, 2017 | 09:37 PM
ddankanyin's Avatar
It wasn't going up, so I removed it from the fender well, opened it up, teeth were OK, greased the gears, put it back together, straightened the mast a little (my wife had a bird strike) it went up and down fine, as it still does, just opposite of when it should. I had just replaced both heads and all of the timing components, and installed a header system w/LCE EGR delete, so it hadn't run in a couple weeks, runs great now, but I would like to get this fixed. I've browsed this site as a guest for years, and gotten great info, I was really hoping for a simple way to re set it, like the ECM---- thanks again, Doug
ddankanyin's Avatar
stock stereo
Old Nov 2, 2017 | 10:23 PM
75w90mantraN's Avatar
Wonder if the issue started sometime after the bird strike...
I'm just guessing, but could something internal with the antenna motor be knocked out of position to switch functions? Dont think work on the front engine is suspect unless the wiring with the antenna was inadvertently altered in some way.
Old Nov 3, 2017 | 12:12 AM
wyoming9's Avatar
Red face
Some How the Polarity of the Motor has been reversed it might be in the motor it might be in the relay .
The direction changes are all in the relay . Possible you put something together wrong in the gears doubtful because that should be pretty straight forward
Simple DC motor change polarity to change direction .
Any electrical mishaps or wiring changes .
I would love to have this in front of me this is a interesting challenge .
Old Nov 3, 2017 | 05:31 AM
Malcolm99's Avatar
before you disassembled the antenna motor was it in the up position or half way, and when you reassembled it was it in the down position by applying power or did you force it down without the old whip in place, you need to keep it in phase, I would remove the whip, power down position and install whip in down position, while motor thinks it is down, antenna is down, and install whip in the down position.
Old Nov 3, 2017 | 05:38 AM
habanero's Avatar
On 3rd gen 4Runners the antenna motor housing where the magnets are can be installed backwards....if also true for your second gen as I suspect it is and you pulled the motor housing when you took the antenna apart you may have done this. Wouldn't be the first time someone has.
Old Nov 3, 2017 | 06:39 AM
ksti's Avatar
This is exactly what I would do.
Old Nov 3, 2017 | 07:12 AM
ddankanyin's Avatar
I did pull the motor apart and check the brushes, and grease the worm gear, suppose I could have put the housing back wrong. Won't have a day off to open it up again until Mon or Tues.
I'll let you know how I end up fixing it,
Thanks again, Doug
Old Nov 3, 2017 | 06:19 PM
ddankanyin's Avatar
OK here's what transpired; I thought about the possibility of having reversed the leads to the motor, so, I powered the mast down, opened the fender well, upon close inspection, I had flipped the motor housing so flipped it back. At this point, the radio is on, the antenna is down. I then unplugged the motor, and turned the radio off, I could hear the relay click. now the radio is off, antenna is down, plugged the motor back in, turned on the radio, antenna goes up, off down--fixed.
It's pretty funny how these little things bother me more than the big things, thanks for the input guys this site has helped me out numerous times, I used to have 2 Toyotas, down to one now.
Thanks again, Doug
Old Nov 3, 2017 | 07:26 PM
habanero's Avatar
Thanks again, Doug
Good old reversed polarity- wyoming9 nailed it. So glad you got the problem solved and even happier you shared the fix with us guys and girls.
Old Nov 4, 2017 | 01:11 AM
wyoming9's Avatar
Red face
Glad it was a simple fix!!
Scjarena
Jan 6, 2023 06:11 AM
Jeff Bouchard
Sep 27, 2017 06:58 PM
bootstrap
Aug 23, 2017 06:35 PM
nikkshepherd
Aug 23, 2017 05:32 AM
altitude30717
Aug 13, 2017 11:09 AM
