98 Tacoma random headlights failure
Old Nov 17, 2015 | 03:54 PM
RedRobert's Avatar
So this is strange, and I've read through many previous similar posts, but I'm not seeing what I need...
Hi beams work, as well as running/parking lights and turn signals etc etc etc...
However, when I need my low beams, sometimes they work, sometimes not. sometimes they cut in and out driving down the road. Sometimes only one of the low beams works and the other does not. (wtf)
When they are not working, the hi beam indicator comes on.
fuses good, totally new headlights (the whole assembly, not just the bulbs, I've switched them to leds and yes my wiring is solid)
Fairly certain this is a wiring/contactor sort of issue
Sometimes wiggling the switch works, sometimes bumping the steering column works, often nothing works... please help
Does anyone have access to a diagram or otherwise experience that would tell me where to start looking for this gremlin?
Thanks
-R
Old Nov 17, 2015 | 03:57 PM
RedRobert's Avatar
Mods please forgive me if this should have been posted in the electrical forum... I've been reading these boards for a while, but this is my first post.
Old Nov 18, 2015 | 12:06 AM
wyoming9's Avatar
Red face
How did your lights work before switching to the LED`s
Dirty or burnt contacts in the switch.
Something wrong in the wiring .
Old Nov 21, 2015 | 09:59 AM
RedRobert's Avatar
I've definitely found the bad connection. Unfortunately there's 2.
The one causing my low beams to fail is on the wiring harness connected to the combo switch here.
The one causing my right headlight to fail now and then is in the 3 prong plug at the headlight.
I guess my question now becomes, can I re-pin the bad wire on the harness? I'm not having any luck removing it, but it needs to be seated better.
Old Nov 22, 2015 | 09:09 PM
TheDurk's Avatar
Your answers are in here:
Wire Harness Repair Manual
In this several hundred pages of official Toyota goodness, you can look up your connector part number, and find the p/n of the repair wire for that connector. Some connectors use more than one type of repair wire. The manual shows this. The repair wire is the metal contact with a short length of wire attached. The manual also explains the tricky feat of how to get the old contact out and slide the new repair wire in. Then you splice the repair wire to whats left of the old wire.
The dealer will be happy to sell you a repair wire if you know the p/n; he won't look it up for you. At least mine won't.
Old Nov 23, 2015 | 08:14 AM
RedRobert's Avatar
Man this is awesome. Thanks a lot.
RyanJ989
11
Apr 7, 2021 09:41 AM
Jason4X4
Sep 17, 2015 08:02 AM
89hilux1
Sep 14, 2015 06:13 PM
dguzzi
Sep 3, 2015 08:48 AM
swerks
Aug 23, 2015 06:32 AM
