3.4 jumping time repeatedly
Old Nov 30, 2015 | 11:11 AM
coleypull15's Avatar
98 4runner giving me fits, all of a sudden wouldn't crank. Finally figured out its out of time. Put new belt on. Cranked ran fine. Cranked to go to work next am, and could hear teeth slip... So now we are on the 4rth timing belt and I replaced the tensioner. It may crank 2 time then slip the 3rd. 2nd belt cranked 15 times. Anyone know whats causing this? Backfire through the manifold? Any help much appriciated
Old Nov 30, 2015 | 06:11 PM
Jomoka's Avatar
With the belt off, try cranking the cams around. One may be unusually stiff. If so, that's a big problem. Also, spin the water pump around and make sure it's free.
Old Nov 30, 2015 | 06:37 PM
rworegon's Avatar
.....and you are pulling the pin on the tensioner?
Sounds like something is binding up in the valve train, water pump, etc. or something is not installed correctly.
Check that the pins that hold the cam gears in place are in good shape and also the crank gear key. Trying to eliminate points of slippage....
Old Dec 1, 2015 | 11:32 AM
donomite49's Avatar
Flywheel key sheared?
Old Dec 2, 2015 | 07:32 AM
vasinvictor's Avatar
Some very good suggestions fella! OP, what have you figued out?
Old Dec 6, 2015 | 08:35 AM
rworegon's Avatar
OP, any update?
Old Dec 6, 2015 | 02:26 PM
wyoming9's Avatar
Red face
I would like to know as well what the issue was???
Old Feb 25, 2016 | 06:29 PM
Sorry for following up, but thay last belt i put on it lasted untill the other day. Cold for alabama at 30 degrees went to crank and it slipped again!! I went on with my day and when I got home I noticed all the coolant was on the ground also. So maybe a water pump issue?
Old Feb 25, 2016 | 06:37 PM
Dude, we'very given you almost every reason possible this could be happening. Time to tear it apart and investigate.
Old Feb 28, 2016 | 05:24 AM
Dude, your a genius. Thank you.
FRANCOARMANI
Oct 19, 2015 07:33 AM
Griff
Oct 14, 2015 11:21 AM
Deeraholic
Oct 12, 2015 08:58 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
PBRaddict#1
Sep 22, 2015 07:50 AM
