Suspension lift question
Old Dec 10, 2015 | 04:50 AM
Cole Adams's Avatar
I purchased a lift from toytec. It's the 3'' lift/leveling kit for my 2001 tacoma. I currently have 31'' tires. Once I get the lift on and move up to 33'' tires how much taller will my truck sit? Exactly 3'' taller? Or more because of the bigger tires? Any help appreciated!
Old Dec 10, 2015 | 07:00 AM
habanero's Avatar
Toytec expects you'll get 3" from the lift, not the tires....
No matter how high you lift or not lift, putting taller tires on will raise the truck at the hubs.
If you have 31" tires and move up to 33" tires you'll be 1" higher...
EXCEPT
31" tires are not always 31" and the same goes for 33" so results will vary.
Old Dec 10, 2015 | 07:03 AM
Malcolm99's Avatar
Not a great question. Tires brands are not all exactly the same size even when it says so, so exact size will depend on make and model air pressure ect, now to answer your Q, if you have 31" tall tires and go to 33" you gain 1" of height/clearance in a perfect world from the centre of the hub,...now the lift kit height would depend on the factory springs/original height, so some gain 1" suspension lift and some get 2.5" up front, the rear should get the full 3" plus your 1" tire height. So technically you only gain 1" of clearance of the lowest part of the vehicle.
Someone beat me to it but the math is off*
Old Dec 10, 2015 | 08:24 AM
Cole Adams's Avatar
Ok thanks for both answers.
Old Dec 11, 2015 | 08:24 AM
vasinvictor's Avatar
Originally Posted by Malcolm99
Someone beat me to it but his math is off*
his is a actually a her :-)
Old Dec 11, 2015 | 08:30 AM
Malcolm99's Avatar
my honest mistake, fixed it
Old Dec 11, 2015 | 11:47 AM
habanero's Avatar
Ha, you're right....had 3 in the head and it got stuck. I've edited to reflect that.
Dustin Egle
Mar 4, 2016 09:47 AM
kioti
Dec 10, 2015 12:24 PM
mapemberton12
Dec 10, 2015 06:42 AM
Blillyyota
7
Nov 29, 2015 08:07 PM
rugerm44
Nov 12, 2015 02:20 PM
