wierd idle, anyone have this?
Old Feb 15, 2005 | 09:18 PM
green91runner's Avatar
only happened twice now.. but after running my truck for a bit and then shutting it down (5-20min) and coming back out to fire it up again, the engine idles at about 500rpm (normal idle is 750-1000), and the oil pressure is very low, first time it happened, i hit the gas to bring it up, but it just stayed at 500. shut it off, turned it back on and it was fine, 2nd time, when i hit the gas it went up to normal revs. when i do start it up, it is in gear and doesn't move, so i dont think it could be the clutch?
as for the clutch, I think its going, or just setup wrong, or now going because it's setup wrong. lol
hoping that this doesn't happen again... maybe all the work being done at the stealership will fix, whatever is causing this.
Old Feb 15, 2005 | 09:53 PM
Yota4runner's Avatar
Not sure mine idles low and always has, definetly sounds like you got some problems with your clutch though. Mine has done this a couple times, I haven't honestly been able to come up with a solution and it doesn't appear to be hurting anything so I don't mind it all that much.
Side note: Where abouts in Ontario are you? /side note
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
