4x2 Rear to SOA
Old Feb 17, 2005 | 08:06 PM
jimbo74's Avatar
4x2 Rear to SOA
ok, i am seriously contemplating making the rear of my truck SOA, as the 4x2s had an SUA setup....
i know i will need spring perches welded on, new shock mounts, ubolts, spring plates....
what issues will i run into as far as the brake system? i already have extended brake lines... i dont see how the soa conversion would interfere with anything but i might also somewhat redesign the current brake line setup so they cant accidentally drag on anything or make a custom skidplate for the brakeline.....
i might end up adding some custom realignment shims after the soa, as my truck is lifted 2" above stock now and and soa will lift it anotehr 3-4" i beleive and the 4x2 was never meant to see a angle like that....
Old Feb 19, 2005 | 03:10 PM
Cebby's Avatar
What are you going to do up front? BJ Spacers?
The only issue aside from the obvious fab work is possible vibration which you've addressed with the shims. Maybe take a look 2WD vs 4WD driveshafts and see if they are the same. You could be OK if they are.
Old Feb 19, 2005 | 03:17 PM
jimbo74's Avatar
i plan on keeping the same driveshaft....
i will be adding bj spacers up front, sdori is making them for the 4x2 trucks, they arent available yet though
Old Feb 19, 2005 | 05:02 PM
terryjmatthew's Avatar
Make sure to compensate the pinion angle before welding on the new perches.
Old Feb 19, 2005 | 05:04 PM
jimbo74's Avatar
yeah thats an idea too
Old Feb 19, 2005 | 05:43 PM
kyle_22r's Avatar
i agree, that's much better than using shims! just figure out the correct angle and weld your perches accordingly.
Old Feb 19, 2005 | 07:13 PM
3car's Avatar
part it out and buy a 4wd truck.
Old Feb 20, 2005 | 02:48 AM
jimbo74's Avatar
4x4s cost too much, even for the crappy ones....
Old Feb 20, 2005 | 08:57 AM
kyle_22r's Avatar
that was a thoughtful response
Old Feb 20, 2005 | 01:15 PM
jimbo74's Avatar
its ok kyle, only about 10% of the people on yt are thoughtful and not buttheads.......
jasonty
41
Dec 23, 2018 01:00 PM
okamikai
Apr 30, 2018 10:19 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
