91 pickup ?'s
Old Feb 18, 2005 | 09:17 AM
Nihil's Avatar
91 pickup ?'s
I'm looking at buying a local yota pickup.
Specs: 91 SR5 5-spd 4x4
What trans & t-case does it have? What's 1st gear, 4x low, and what are the diff gears?
Thans a bunch.
Old Feb 18, 2005 | 09:58 PM
87TurboYota's Avatar
Nothing. I like it. I don't know much about the truck but I'm sure there are a bunch of others that can help you.
Old Feb 18, 2005 | 10:16 PM
bubbamango's Avatar
gears are either 4:10s or 4:56s. most of the models that came with stock 31'' tires were loaded with the 4:56s
Old Feb 18, 2005 | 10:59 PM
Glenn's Avatar
What engine? 4 cylinder or 6?
Old Feb 19, 2005 | 06:29 AM
Nihil's Avatar
SR5 package came with the 3.0
Old Feb 19, 2005 | 09:50 AM
Fahrenheit 451's Avatar
Should be an r150 hooked to a chain drive case.
The transfercase is actually slightly lower geared than a gear drive, but I don't remember the number; 2.93 vs. 2.8 or something like that. First gear in the tranny is 3.83.
Check here to get info so you find out the differential gears it came with:
http://www.brian894x4.com/Gearratiosanddiffs.html
Old Feb 19, 2005 | 05:46 PM
kyle_22r's Avatar
sr5s didn't come with 3.0s. it's just a trim package after '83 on 4x4 trucks.
it can be a 2.4(which would have a W56 and a gear driven case, or a G58 with a chain driven case if it has ADD) or a 3.0(which would have the R150F/chain case)
sandyota
Feb 4, 2021 11:16 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
rondogracing
Jul 14, 2015 07:00 PM
