Halfshafts Playing around!
Old Feb 19, 2005 | 02:44 PM
NathanBERG's Avatar
Question Half shafts Playing around!
I just hoped on the old creeper and went about inspecting the under belly of the old girl. I noticed play in both half shafts. What should I do to fix them? I am guessing they should not have play in them. Also if I need to replace them. what will it cost me in parts?
Old Feb 19, 2005 | 03:07 PM
jimbo74's Avatar
what do you mean by play? there is supposed to be a little bit, just as the rear driveshaft turns a little bit when parked, not much, but still some
Old Feb 19, 2005 | 03:16 PM
NathanBERG's Avatar
If I hold the shaft and then push in towrds the Diff it moves. Also if I push up and pull down it moves. I fuigerd it should turn like the drive line but all the other play is bothering me.
Old Feb 19, 2005 | 03:17 PM
dwh91102's Avatar
are they poping when you turn, or leaking grease?
Old Feb 19, 2005 | 03:18 PM
jimbo74's Avatar
well the way the inside of the cv works, there must be a little play as there are basically flexible joints....., much like the wobbly of a socket set
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
rmill05
Sep 27, 2015 01:43 PM
Toys4parts
Sep 26, 2015 01:56 PM
