Distributor grease?
Old Feb 16, 2005 | 10:48 PM
the_supernerd's Avatar
Distributor grease?
I am planning on doing a partial rebuild on a distributor for my truck. Should I put some kind of grease on the mechanical advance? What kind?
Old Feb 16, 2005 | 11:22 PM
jimbo74's Avatar
di-electric grease might be ok... i wouldnt mess with it too much though... grease has a tendecy to accumulate dirt and grit, and this cuases binding and premature failure due to wear
Old Feb 16, 2005 | 11:35 PM
Do you know what it uses from the factory?
Old Feb 17, 2005 | 08:18 AM
kyle_22r's Avatar
i never knew it had grease in there. i'll take a look at my FSM and see if it shows anything.
Old Feb 17, 2005 | 12:14 PM
I just got a factory service manual for my truck and it says to put grease in the shaft that has the rotor on it, but it does not say what type of grease.
Old Feb 17, 2005 | 02:04 PM
kyle_22r's Avatar
i figure some hi-temp wheel bearing grease would do the trick.
Old Feb 17, 2005 | 04:48 PM
Thanks for the replies. I think I have some hi-temp wheel bearing grease, so I will use some of that.
JonG85
Jan 18, 2023 04:31 PM
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
LittleUgly
15
Jan 2, 2020 01:30 PM
seab1209
Sep 3, 2015 05:41 PM
