Quick Oil Drain Valve.....
Old Jun 18, 2009 | 05:29 PM
FJHammerHead's Avatar
Going to be getting some BudBuilt Skids before long and I was thinking about getting one of these valves before putting on the skids to make oil changes quicker and easier with the skids.
http://www.quickoildrainvalve.com/Pr...ductCode=F103N
Has anyone used one of these before?? Thanks
Old Jun 18, 2009 | 05:55 PM
pmbazus's Avatar
Yes they work great. But they take longer to drain the oil. I really like mine.
Old Jun 18, 2009 | 06:37 PM
corax's Avatar
nice, but I wish they had a threaded cap with an o-ring on it as a safety . . . even though it's probably fine, I just don't trust a valve with my engine's blood
Old Jun 18, 2009 | 06:39 PM
corax's Avatar
I guess I could put a rubber cap on it with a weak spring clamp (bigger than the one in that pic)
Old Jun 18, 2009 | 06:49 PM
BajaRunner's Avatar
Hmmm sounds like a good idea actually!
Old Jun 18, 2009 | 07:32 PM
Lumpy's Avatar
I don't think I'd trust that thing...My luck I'd hit a rock and it would open on a trail for me.
Old Jun 18, 2009 | 09:03 PM
slisdexia's Avatar
I've always been warned against those. No matter how good they are, they just won't be as foolproof as a good ol' threaded plug. If they get bumped the wrong way or something gets stuck in the sealing area... seems to easy to leak. My .02 cents: stay away
Old Jun 19, 2009 | 06:02 PM
Thanks for all the comments. I still like the idea of this valve. I don't think that it would open prematurely because you have to push up on the lever and then rotate it. I really don't want to have to take the skid plates off every time I have to change the oil.
Old Jun 19, 2009 | 06:36 PM
TC4RNR's Avatar
i don't understand why taking the BB skid out is such a big deal. i know it's heavy, all 60lbs of it. but if you can find a cardboard box with the right height sits snag between the ground and the skid, that's all you need, man. just take out the 6 bolts then bull the skid out from front while it sits on top the box, just don't underestimate the strength of the cardboard. plain simple as that, less than 5 minutes of my time. with the skid out, i can inspect the front oil pan, diff. fluid level and other stuff.
i switched to synthetic oil, so i only have to do it twice a year, no biggie.
Old Jun 20, 2009 | 07:43 AM
gtlegs's Avatar
I have that same valve on my subaru. Its been installed for 4 yrs and 70,000 miles. I LOVE it. Mine has never leaked a drop. In fact I had trouble with the copper gaskets on my drain plug leaking all the time before I went to this valve.
Old Jun 20, 2009 | 09:25 AM
Teuf's Avatar
i have had my quick drain valve on for 10 years or so, no probs yet, slow but cool beans
Old Jun 20, 2009 | 09:50 AM
SWPERIC's Avatar
do those to have one put a rubber hose on it to go into your oil pan? i could totally run one thru the skid plate and prevent any mess at all! if its under a budbuilt i cant see it getting disturbed too much. not sure ill get it but its interesting. now that i think about it, ill still have to change the filter which will b messy anyway so forget it.
Old Jun 20, 2009 | 11:07 AM
Teuf's Avatar
mine has no nipple to fit hose, i just use plastic or something to channel it out of way
Old Jun 21, 2009 | 10:46 AM
Terracoma's Avatar
To combat the slow flow rate, I take my truck around the block and drain it as hot as I can.
I've had mine mounted for ~20,000 miles with no issues, whatsoever... I would highly recommend one if you've got a secure skid plate to protect the valve.
Colington
Mar 8, 2020 09:51 AM
jasonty
41
Dec 23, 2018 01:00 PM
yourrealdad
Jul 21, 2015 11:13 AM
kcaudill
Jul 20, 2015 12:06 PM
Gamble_STi
Jul 7, 2015 07:54 PM
