Just swapped in elocker into Taco Now have weird issue
I just swapped a elocker rear axle into my 1997 Tacoma using mt Tacoma 5lug axles.I have driven around quite a bit since I swapped it on Friday evening .It drives well but the weird thing is if you give it too much gas it revs up and I get wheel hop realllllll bad .I know its not locked because I have checked that.But It almost annoying.You can drive it like a grandma all over the place and it shifts perfect but the second you try and gun it it revs up and bounces all over .Anyone have a clue as to what this could be.
The ubolts are very tight and the drive line buts,bolts are tight.Pinion angle is good. No noises but seems like trans is slipping but as soon as I let off the gas then accellerate shifts just fine all the way up to 110mph.
Well after further inspection the pinion is moved slightly more angled upward ,,at least a slight bit more that it was with the other axle.Could that be it
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
