Steering rack questions -inner tie rod
Old 06-17-2009, 08:22 PM
andrewd's Avatar
What my arrows point to? What does that nut do? and the shaft that the inner tie rod end connects to, is it possible to change it out? i believe mine is loose. would it be easier just to change out the shaft or to change out the steering rack itself? this is a diagram from a t100, but if somebody can find a better more exploded view of a 4runner, that would be very helpful
Thanks in advance for the help!
Last edited by waskillywabbit; 06-18-2009 at 05:02 AM. Reason: Please use a title relevant to the subject
Old 06-17-2009, 08:44 PM
toylocost's Avatar
Location: Yotatech, because Pirate is too expensive. NorCal.
Are the new runners rack and pinion??? hmmmm.
Old 06-17-2009, 09:10 PM
Fink's Avatar
I've never seen that part on a 3rd gen - it looks like a mix between a tie-rod and a steering damper....
Fink
Old 06-18-2009, 04:25 AM
crolison's Avatar
Inner tie rod
Old 06-18-2009, 04:42 AM
andrewd's Avatar
Yeah, i know its the inner tie rod end. I just replaced both thinking they were my problem, not true. I was wondering what they connect to? There is a rod thats sticking out that you screw them onto. My question is can this be replaced? If you want a better pic just ask ill take an actual picture of what im talking about
Oh and fink, no offense, but you must not have looked underneath a 3rd gen 4runner lol
Old 06-18-2009, 03:54 PM
Nuthuts96's Avatar
Location: Shelburne, VT previous: Everett, WA; Bellingham, WA
pretty sure that's the actual steering rack. it's toothed, and runs the length of the rack's housing. here's another (4runner) picture...
Old 06-18-2009, 04:19 PM
Godzilla's Avatar
If the inner actual rack is moving then your rack is shot, more likely the internal bushings and seals. You could rebuild a rack, however it will be cheaper and easier to replace it.
As for the inverted nut, it is the rack guide and from what I have read before you can use it to tighten the rack up. Here are the torque specs; http://www.ncttora.com/fsm/1996/SIL/...r/psg/reas.pdf
Just watch for the beginning of leaks from the inner rack,.
Old 06-18-2009, 10:11 PM
andrewd's Avatar
very good thanks guys! I will probably just end up swappin out the whole rack
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
cgilley
07-25-2015 10:55 PM
ripp96
07-25-2015 02:32 PM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: Steering rack questions -inner tie rod
