problem with 96 tacoma 2.7
Old Jun 13, 2009 | 09:37 AM
hayduke's Avatar
i,ve been burning out plugs on the cylinder that you have to take the air intake off to get to. the last one got so hot that the ceramic that surrounds the electrode actually cracked and half of it was missing when i pulled the plug out. using the factory denso plugs. truck is approaching 250k. also i want to switch to ngk plugs but cant seem to search this forum. the # i came up with off the internet is ngk bkr5es. would that be the correct plug for my truck?
Old Jun 13, 2009 | 09:52 AM
Skrillah's Avatar
Yeah that is the correct plug. You could use a higher end plug like one of the iridium ones which may help also.
The Denso's are decent but I've always stuck to the NGKs and been fine. Especially if you are just using the standard plug. I have used the Denso iridium plugs with fine results but have always felt NGK to be superior. That could just be a perception I've gotten from everyone else on this forum...haha :-)
I'm not sure why you experiencing melted plugs though. I assume due to it being the wrong one or just a low quality plug. Have you experienced other overheating issues of any kind or a misfire in one of the cylinders?
Old Jun 13, 2009 | 09:55 AM
DeathCougar's Avatar
Is your exhaust manifold cracked?
Old Jun 13, 2009 | 09:58 AM
hayduke's Avatar
its just the plug in the #3? cylinder that burns out, the one thats hard to get to.
no real overheating issues, dealer installed densos, no misfire with fresh plugs but after it starts to burn out the plug the misfire obviously gets really bad.
Old Jun 13, 2009 | 09:59 AM
Skrillah's Avatar
Good question!? Which would then equal bad valves...
hayduke's Avatar
i dont think so, i had a crack in my old trucks manifold and i could hear the exhaust leak.
Old Jun 13, 2009 | 10:12 AM
Skrillah's Avatar
Could be worth checking on though...its weird that just the #3 is doing that. It may be a good idea to get a compression and/or leak down test on it to be sure.
250k miles...not bad...anything major besides this happen to it? I'm at 148k and going strong (knock on wood**)...did you need a valve job or anything?
Old Jun 13, 2009 | 11:27 AM
take off the heat shield, I bet you find a crack
Old Jun 16, 2009 | 03:45 PM
hayduke's Avatar
pulled off the heatshield today and there are no cracks.
i talked to a friend who is a mechanic and he thought an injector may no be firing right??
Old Jun 18, 2009 | 06:43 PM
96redtoy's Avatar
my bet is on DC
my manifold crack was at #3 exhuast port
spray some PB blaster all over the manifold and let it set for a little while if there is any cracks in the manifold the penitrating oil will seep into the crack and the metal will look wet around the crack. It might be on the engine side of the manifold also.
But you said you did not hear anything or see anything so IDK
also check to see if the plug wire is shorting out somewhere along the way. Maybe a set of OEM plug wires.
Old Dec 22, 2009 | 08:04 AM
hayduke's Avatar
update:
so last june i replaced all the plugs with ngk's and it ran great up til a month ago when the #3 plug burnt out again (cracked ceramic). the cylinder seemed to be pretty hot when i replaced the plug. ran good for another month then just the other day it crapped out. blew the spark plug out of the engine. it happened when the engine was under load as i was gasing it up a hill. anybody have any idea what happened?? should i be looking for a new engine? the spark plug was properly torqued and there was never any previous thread damage. it will still run, just really really rough.
Old Dec 22, 2009 | 09:46 PM
space-junk's Avatar
the cylinder was what?!?!?!
Old Dec 23, 2009 | 07:46 AM
The cylinder merely was, Troy. Sheesh, try and keep up.
The cylinder was an entity; an enlightened being. "The cylinder, WAS". And that is all there is too it!
Old Dec 23, 2009 | 08:22 AM
BoostedRNR's Avatar
Tight valve on that cylinder?
Old Dec 24, 2009 | 03:23 AM
space-junk's Avatar
thank you sensei...
Old Dec 25, 2009 | 05:56 PM
hayduke's Avatar
my bad. i dont know wtf happened there.
reread post 11.
smthwsn357
May 1, 2024 07:28 AM
94whiterunner
Jul 12, 2015 07:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
akaphilly
Jul 9, 2015 02:18 PM
