universal synthetic transmission fluid. Any Good?
Old Sep 17, 2012 | 03:23 PM
JesseS's Avatar
Got a price to do a transmission fluid change and the shop uses a synthetic that they swear by. It has a long list of fluids that it can replace including all of the dexrons 1-6. Just wondering if its any good or if I should stick to the dexron 2 or 3. not sure if I can post this link but its made by service pro and is a full synthetic. Thanks Jesse http://www.service-pro.com/documents...VehicleATF.pdf
Old Sep 18, 2012 | 04:51 AM
J2F42C's Avatar
It sounds as if you are fine. Drive on.
Old Sep 18, 2012 | 06:43 AM
MudHippy's Avatar
x2, you're good to go.
Interestingly enough, I found another universal ATF/PSF like that one recently. While searching for the ever elusive Toyota PSF Type EH(P/N 008886-01). Which I eventually found(proving it really does exist). But that's not exactly relevant...at the moment. However, the quote I've taken from this TDS is...
Technical Data Sheet
Divinol ATF-C Premium VI
Product description
Divinol ATF-C Premium VI is a clear colored power transmission oil for automatic transmissions and offers following
characteristics:
• Superior oxidation stability
• Very good anti wear characteristics
• Premium cold flow properties
• Broadly temperature range deployment
• Not aggressive to any sort of seal
• Very good shear stability
• Suitable for prolonged oil drain intervals
• Universal deployable ATF
Specification
GM Dexron VI; GM Dexron III G/H; GM Dexron II D; GM Dexron TASA; Ford Mercon V; JASO 1 A
Manufacturer performance
Allison C4 / TES 295; BMW 7045E / 8072B / LA2634 / LT 71141 / P/N 83220142516; Chrysler ATF; Honda ATFZ1;
Hyundai SP-II / III / SPH IV* /NWS 9638*; JWS (Aisin Warner) 3309 / 3324*; KIA SP II / III; MAN 339 V2/Z2
sowie 339 F; Mazda ATF M III/V; MB Freigabe 236.1 /236.2 /236.3 / 236.5 / 236.6 /236.7 / 236.9 / 236.10 /236.11;
Mitsubishi Diamond SP II/III/IV/ATF-J2; Nissan Matic D/J/K/S; Nissan 402; Subaru ATF / ATF HP; Saab 93 165 147;
Suzuki 3317; Toyota T III/IV/WS; Volvo 97340 / 97341; VW G 052 162 / G 052 990 / G 055 005 / G 055 025 / G 055
162 / G 060 162; ZF 03D,04D,05L,09, 11B,14A,14B,16L, 17C
Tests for Voith H 55.6336 approval done until 2012.
* Suitable after OEM car warranty
Recommended as servo oil for following cars:
Acura P/N 08206-9002 A; Chrysler MS-1872, MS-5931, P/N 04883077, MS-9602, ATF+4; Ford M2C 195-A; GM
P/N 89021184, GM 9985010; P/N 1052884; GM 9985835; P/N12345866; Honda P/N 08206-9002 A; Hyundai PSF-
3; Kia PSF-3; Mercedes-Benz 236.3, P/N 000 989 88 03; Mitsubishi PS Fluid, Diamond SP III; Nissan PSF-II;
Saab P/N (45) 30 09 800; Subaru P/N K 0209 A 0080; Toyota PSF Type EH, P/N 008886-01
Characteristics
Density/15°C / DIN 51 757: 848 kg/mł
Colour / DIN ISO 2049: Clear
Flash point (Cleveland) / DIN ISO 2592: 208 °C
Pour point / DIN ISO 3016: <-35°C
Viscosity/100°C / DIN 51 562: 7.5 mm˛/s
Viscosity/40°C / DIN 51 562: 36.7 mm˛/s
Viscosity index / DIN ISO 2909: 181
Application
Divinol ATF-C Premium VI is suitable as transmission oil in automatic transmissions of cars, trucks, busses and
special vehicles. Also possible for hydrodynamic converters, hydraulics and servo-steerings in accordance to
manufacturers` specifications.
Old Sep 18, 2012 | 07:55 AM
JesseS's Avatar
thanks guys. Im enjoying reading through this forum. Learning a lot
Old Sep 19, 2012 | 12:49 AM
ARB1977's Avatar
Amsoil Universal is what I use. 141K going strong.
Old Sep 19, 2012 | 09:02 AM
MudHippy's Avatar
EDIT: Yeah...nevermind. I had something else to say. But I changed my mind. It was off topic anyway.
Old Sep 22, 2012 | 04:58 AM
Potomacduck's Avatar
The 4runner transmission holds a lot of ATF and a full synthetic changeover will be expensive.
I've got 331,000 miles on regular over the counter ATF and she's still going strong.
Don't waste the money............just my opinion.
Old Sep 22, 2012 | 09:19 AM
MudHippy's Avatar
That's kind of a relative statement, don't you think? A lot compared to what?
A340E:
Dry fill 7.2 liters (7.6 US qts, 6.3 Imp.qts)
Drain and refill 1.6 liters (1.7 US qts, 1.4 Imp.qts)
A340F:
Dry fill 10.2 liters (10.8 US qts, 9.0 Imp.qts)
Drain and refill 2.0 liters (2.1 US qts, 1.8 Imp.qts)
ATF D-II or DEXRONŽ III (DEXRONŽ II)
http://ncttora.com/fsm/1996/SIL/tech...pp/at/lubr.pdf
...a full synthetic changeover will be expensive. Don't waste the money............just my opinion.
I agree. Considering that full synthetic ATF is generally almost 2 to 3 times the price of good ol' DEXRON III(or equivalent). ~$3.50/quart vs. ~$6-$10/quart. And if you're talking between 8 and 11 quarts to dry fill a tranny(or more to flush it), it adds up...QUICK!
If I was rich, I'd use synthetic. But since I ain't, I just make sure that any automatic transmission I own gets flushed + a new filter + refilled with the cheap stuff every 30k miles. Which is usually more than adequate preventative maintenance wise.
kazuya2416
Apr 5, 2024 02:17 AM
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
