Leaf springs uneven
Old Oct 12, 2012 | 07:16 AM
mschein1's Avatar
Leaf springs uneven
Hey all, was greasing up the drivetrain the other day when I noticed the leaf springs were un even, as in not all lined up correctly. The greasing of the drivetrain did not cure my issues of creaking when taking off from say a stop light/stop sign. I know it needed greasing as it is much smoother now.
Now with these leaf springs, how do they become uneven like this? Could they be loose? Is it unsafe to drive like this? Can I just jack up the rear to take enough pressure off of the springs that I can straighten them out and tighten up the C clamp?
Old Oct 12, 2012 | 07:24 AM
waskillywabbit's Avatar
Tacoma? Pics would help to be sure what you are talking about.
:wabbit2:
Old Oct 12, 2012 | 07:30 AM
mschein1's Avatar
Yes sorry 99 Tacoma with 6 inch lift. Will go snap a pic in a few.
Old Oct 12, 2012 | 07:59 AM
mschein1's Avatar
The first pic is the driver side, you can see how it is angled out about 1/2-1 inch. The second is the passenger side, hard to tell from the pic but it is angled 1/2-1 inch the opposite way of the drivers side.
Old Oct 12, 2012 | 11:08 AM
mschein1's Avatar
did the pics show up? images are blocked at my work so I cannot tell.
Old Oct 12, 2012 | 03:00 PM
scuba's Avatar
You can remove the u-bolts, drop the axle a few inches, hammer the springs back into phase, and then tighten the center pin.
It is not recommended to re-use u-bolts.
Old Oct 12, 2012 | 03:20 PM
drew303's Avatar
I don't know anyone who doesn't reuse the bolts.....
Loosen the ubolts hammer the plates straight and tighten em back up. Looks to me like they aren't tight enough.
Fyi its not uncommon for the plates to move like that
drew303's Avatar
And as scuba said, might try tightening the Center pin.
Old Oct 15, 2012 | 04:45 AM
mschein1's Avatar
thanks guys!
ZGjethro
Jun 7, 2017 11:04 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
