97 4runner no heat
Old Nov 6, 2018 | 06:13 AM
dsoucy's Avatar
97 4runner no heat
97 4runner sr5 no heat, not thermostat, not water valve, not core plugged, coolant is circulateting ?????? HELP PLEASE.
Old Nov 6, 2018 | 06:45 AM
millball's Avatar
Try to determine if the control cables are properly connected to the air blend doors under the dash; and that those doors move appropriately.
No air thru the heater core: No heat.
Old Nov 6, 2018 | 02:33 PM
RAD4Runner's Avatar
Air blend doors under the dash as suspect makes sense.
I saw similar thing just last Sunday while in the process of flushing the cooling system of a 1999 4Runner.
The plastic fitting on the heater control valve in engine compartment broke so I bypassed it with a straight fitting. That means coolant was getting to the heater core. However, there was still no hot air with blower on. Turning the temp adjust knob got me hot air.
At first I thought that the heater control knob opening the valve was all that's needed. I did not realize there's still the "air blend door" to deal with.
Old Nov 7, 2018 | 09:48 AM
akwheeler's Avatar
this may seem stupid, but.... is the fan blowing air? you didn't mention it.
Old Nov 7, 2018 | 12:22 PM
75w90mantraN's Avatar
https://www.yotatech.com/forums/f116/no-heat-306138/
OP fixed it in a redundant thread. Duplicate in this section.
warrpath4x4
72
Jan 31, 2020 12:18 PM
ev13wt
Nov 7, 2018 01:55 PM
sportinh2o
Nov 6, 2018 12:49 PM
Pom85627
Oct 23, 2018 04:45 PM
Canyonfrog
Aug 22, 2018 06:31 PM
