Stock Front Bumper
Old Jan 14, 2008 | 03:44 PM
Geographeen's Avatar
Stock Front Bumper
Does anyone know if I will be facing any issues (rubbing?) with the stock front bumper of a 2000 Limited when trying to fit 285's? I currently have an OME lift and will soon be adding a 2" BL. When the BL goes on, I will be swapping out my stock 5 star wheels for MT Classic II's with about 4" backspacing, to go with the 285's.
Old Jan 14, 2008 | 03:52 PM
MillerPKA's Avatar
you'll be fine man, the new backspacing just assured that. i'm running the 5 spokes with the 883s up front and 2" body lift, i just rub the a-arm, i really need to get some 1/4" wheel spacers, everywhere else i have more than enough room to run 35s
Old Jan 15, 2008 | 04:16 AM
The stock front bumper hangs a little lower inside the wheel well compared to your ARB.....do you still think I will clear?
Old Jan 15, 2008 | 05:54 AM
MillerPKA's Avatar
i think you may have some rub and full turn but a little snipping inside of the fender well on the affected areas and you should be fine...as long as you're getting the mounting brackets for the bumper for the body lift
88sasturbotoy
Jan 30, 2026 01:57 PM
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
