diff drop, need more than 2 inch?
Old Jan 9, 2008 | 09:32 PM
TacoTime's Avatar
Question diff drop, need more than 2 inch?
I recently installed toytec 3inch with aal, I also added a two inch diff drop also toytec
My problem is I still have slight vibs in the front, not bad but I like no vibs.
Has anyone add more than two inches of drop on the diff? I think another 1/4 inch and it may solve my vibs.
anythoughts
thanks
Old Jan 9, 2008 | 09:34 PM
muddpigg's Avatar
Did you check angles of drive line.
Old Jan 9, 2008 | 10:09 PM
TacoTime's Avatar
front u joint angle doesn't seem to shabby, I know they can be touchy but I was thinking the vibs were originating from the CVs
Old Jan 9, 2008 | 11:43 PM
hiloracerboy84's Avatar
toytec has a 2" diff drop?
Old Jan 10, 2008 | 02:49 AM
KZN185W's Avatar
After putting on Sonoran Steel's 1" diff drop, I tried to put in a 1/2" additional drop bit it would't fit. I had to shave a few millimeters to be able to fit it in (about 10 mm thk).
Old Jan 10, 2008 | 06:53 AM
Skrillah's Avatar
x2 .....???
Old Jan 10, 2008 | 08:45 AM
ninjarunner's Avatar
i dropped my diff way more then 2in, it was more like 6. i put the fabtech tacoma lift on the front my runner and it came with new frame cross members... sorry just thought I'd throw that in there
Old Jan 10, 2008 | 01:34 PM
4Runner202020's Avatar
x3...
Old Jan 10, 2008 | 03:48 PM
Ultraman V's Avatar
I kinda think you may be looking in the wrong place.......my Taco has a 3" lift with 33's and up until about a month ago no diff drop at all, and I had no vibrations. I recently installed a 1" drop and noticed no difference as far as vibrations are concerned. Have you greased your ujoints up front lately?
Old Jan 10, 2008 | 09:19 PM
TacoTime's Avatar
thanks for the tips KZN185W and Ultraman V
hey KZN, why did you add the added 1/2 where you getting vibs, and did the add 1/2 help?
Old Jan 11, 2008 | 02:05 AM
KZN185W's Avatar
TacoTime,
the intention was to increase the drop to reduce cv angle. No vibrations too.
Old Jan 13, 2008 | 03:05 PM
TacoTime's Avatar
I don't think i'm being clear, I'm running a 1 inch drop, not two inch.
For some odd reason I thought it was two, hence all the "toytec has a 2inch"
So, with a one inch drop and still getting vibrations felt through the dash; does anyone think adding an additional 1/2 would help?
Old Jan 13, 2008 | 05:23 PM
you will not get vibrations from it with or with out a drop. unless the drop was done and you screwed up something else. many people i know have run those lifts for years without a diff drop(myself included) with no vibrations, you are chasing and invisible cat.
Old Jan 13, 2008 | 05:30 PM
get your tires rotated and balanced. lol could be simple...haha
Old Jan 14, 2008 | 10:30 AM
skjos's Avatar
Did you get a front end alignment after the lift was completed?
Luvmeye22re
Aug 4, 2015 03:53 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
