*clunk* from the front left when i hit a bump
Old Jan 1, 2008 | 08:59 PM
fireteacher's Avatar
Just started after my last wheelin trip. not sure if i did something out there or in a pot hole around town but when i hit any descent sized bump, there is a clunk coming from my front left; possibly wheel area.
I though it might be a loose light in the TJM, nope...
Thought it would be the battery loose, nope...
CV's "look good, no grease anywhere
going to check the ball joint tomorrow afternoon when i get off (jack it up and shake the tire top and bottom)
could it be that the shock is bad up there? not sure that they were changed before but i was planning on changing them soon, just not sure if that will fix the problem.
anyone else have any ideas or had it happen to them?
Old Jan 1, 2008 | 09:00 PM
ozziesironmanoffroad's Avatar
i had a clunk from the back when i would hit a bump.. was freakin me out... checked the spare tire, and it was loose. lol. it could be your hub bearing.
Old Jan 1, 2008 | 09:11 PM
i will have to look it up in the manual on the extent to repair/trouble shoot when i get home. tough project if it is the culpret? i dont drive with the spare back there (5miles to work) i got almost a 1/2" of lift taking it out!! its just so off balanced!!!
Old Jan 1, 2008 | 09:49 PM
seanz0rz's Avatar
Guest
check that on the front strut component the bushing between the shock and the top plate (inside the coil) is still there.
Old Jan 1, 2008 | 10:16 PM
will do that. i bet your right because it is only when it compresses. do these come out often? i hope it wont be a PITA to replace and hope it can wait until i get new shocks.
Old Jan 2, 2008 | 04:39 AM
GOH10 Runner's Avatar
check your sway bar links
Old Jan 2, 2008 | 08:46 PM
unitofstuff's Avatar
Seconded, my front right clunked when I had a broken endlink (in the front right).
jasonty
41
Dec 23, 2018 01:00 PM
May 20, 2016 10:27 AM
shisha1999
Mar 16, 2016 12:25 PM
coffey50
Jul 28, 2015 10:55 AM
