Horn
Old Jan 9, 2008 | 03:54 PM
hopper's Avatar
Horn
One of my horns crapped out on me. I have a high pitched squeal now.
What horn/ horns could I use in place that uses stock wiring and don’t require new relays?
I have found the Hella horns but $50-90 for horns it a bit much.
Old Jan 9, 2008 | 04:10 PM
Fo_SheeZy's Avatar
I've got some Hella Supertone horns (I think that's what they are called). Got them for $70 out of the performance magazine.
Old Jan 9, 2008 | 05:55 PM
FullXTR's Avatar
ONE of your horns, how many horns are on your truck?? Anyways, it's just a horn - not exactly a performance part - just go buy another stock horn, then you'll know it'll fit. They're only like $15.
I hear ya on the high pitched squeal though - before I got a new one mine sounded like a cross between a wounded crow and someone clubbing a baby seal. I don't think it liked the frequent water submersions.
Old Jan 9, 2008 | 06:09 PM
Spence1016's Avatar
most vehicles im seen have two horns. I have piaa 'sports horns" but am not impressed with them. I agree just go pick up another stock one.
Old Jan 9, 2008 | 06:19 PM
hopper's Avatar
The stock plug (the wiring that plugs into the horn) broke off as well. Im not sure what im going do... just wanted options.
Old Jan 9, 2008 | 08:03 PM
Elton's Avatar
i took the horns off my sisters 97 jetta there plenty loud its just a plug and play installation
Old Jan 12, 2008 | 11:30 AM
Fo_SheeZy's Avatar
Anybody know how to get these Hella horns to work? The stock horns only have 1 wire that plugs into the horn. As for the Hella's, there are two, how can I get these to work?
Old Jan 12, 2008 | 11:50 AM
Elton's Avatar
cut the factory plug then run a new connector to the hella then a ground to the other plug on the hella
Old Jan 12, 2008 | 12:11 PM
pdyebrasil's Avatar
I just bought some FIAMM horns for about $30 from Pepboys or Checkers... and they are a million times better than the stock horns. They fit fine and just plug right in. Make sure you get one low and one high though.
Fo-Sheezy, just ground the other wire and it'll work just fine.
Old Sep 2, 2008 | 10:41 AM
gene74's Avatar
sorry for reviving this old thread.
i don't need to use the relay that came with it?
mussy01
Dec 13, 2016 08:20 PM
xzen73x
Sep 14, 2015 03:00 AM
Curbstomp336
Aug 30, 2015 07:20 AM
ToyoToler
Aug 8, 2015 08:43 AM
jimkoz26
Aug 5, 2015 03:15 PM
