Clutch pedal will not fully retract?
Old Jan 17, 2008 | 04:49 PM
22R-to-5VZFE's Avatar
MY 96 SR5 4runner's clutch will somtimes not fully retract. After I press it in to shift, some times it only comes back half way. Clutch is still working fine but I will physicaly have to pull it backup with my foot some times to its original resting position.
211,000 miles and the clutch is supposed to be new. I just bought it 4 months ago. I'm sure it is that is, that would be a dam long time for an origanal OEM. Spring maybe? Lacking lube or somthing?
No sqeaks or anything. Can't feel friction by any means when using it. any help would be appreciated.
Old Jan 17, 2008 | 04:58 PM
INFINITY's Avatar
check the return spring on the petal and also see if the pivot on the petal is all gummed up with crap. that is where i would start.
Old Jan 17, 2008 | 08:17 PM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
it'd be easy to diagnose yourself once you shine a flashlight up on the clutch pedal and take a look. My bet is it's the spring not so "springy" any more. I replaced my return spring with a linear return spring from a hardware store, and it works well. Just take a look and tell us what you find!
Old Jan 18, 2008 | 12:46 PM
Cool i'll crawl under there right now and check...
Old Jan 18, 2008 | 12:58 PM
pkt1213's Avatar
I just ordered a return spring for a 2nd gen 4runner to get rid of that torsion spring. It had been making creaking noises and today it got worse and didn't come back up the last 1/2 inch. Cost me $6 and I should have it tomorrow.
Old Jan 18, 2008 | 01:21 PM
flyfishexpert's Avatar
Check this out Unhappy99 Spring Mod
This is what I did, linear spring as stated above, and I am very happy.
Old Jan 18, 2008 | 03:34 PM
Looks like the spring it self is stretched out a bit...so a new spring it is. Thanks guys...
Old Mar 1, 2008 | 03:50 PM
Hey in a second part to this question how much does a new clutch with installation cost? OEM and maybe a price on a good aftermarket stage 2 or somthing similar?
I tried searching but i can only find do it your self stuff...what would the cost be at a respectable mechanic? Resurfaced flywheel ect...the works.
okamikai
Apr 30, 2018 10:19 PM
94yota212
Sep 1, 2015 08:01 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
