4Runner - sticky front brake calipers?
Old Jan 8, 2008 | 05:25 PM
jim1000's Avatar
I have a 1999 4Runner V6 2WD with about 115,000 miles.
Occasionally, I hear noise coming from my front driver-side brake.
The sound is identical to gentle screeching sound indicating the pads need to be replaced. But, I had my front pads and rotors completely replaced at about 25,000 miles ago (Performance Friction pads and Brembo rotors), and I still have plenty of pad thickness left. Also, the sound only comes from the driver-side front brake.
Any ideas on diagnosis and cure for this problem?
Old Jan 8, 2008 | 05:45 PM
misterzee's Avatar
Your title probably hit the nail on the head. Replace em.
Old Jan 8, 2008 | 05:48 PM
jim1000's Avatar
Replace the calipers? Is that necessary - in other words, is there no fix without replacing - like grease, etc.?
Old Jan 8, 2008 | 06:35 PM
misterzee's Avatar
In my experience, by that age, brake calipers/pistons/cylinders can get hung, or stick, essentially, "go bad". They don't cost that much, my practice is to buy new loaded calipers, turn the rotors, (or replace if they are already cut down too much). Don't scrimp on your brakes.
Old Jan 8, 2008 | 11:36 PM
Midget96's Avatar
There's nothing to grease on fixed calipers, so no dice there.
A caliper rebuild kit from Toyota is $25 or so, and it does both calipers. Takes a few hours to do.
Compare that to $80+ each for a reman caliper.
Hell, you do 90% of the work to install a reman caliper, why not just take another 20 minutes to replace the boots and seals and save $150?
Rebuilding the calipers requires compressed air, though. No way you can do it without it...
Old Jan 9, 2008 | 12:01 AM
CyMoN's Avatar
I made a tool out of wire to pull the pistons out and it is still a pain napa sells rebuild kits for 10$ per side.
you do save money doing them your self but it is time consuming also if the pistons are pitted I would suggest replacing them.
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
