Which starter do I have?
Old Jan 7, 2008 | 06:14 PM
bmwpower's Avatar
99 Tacoma, regular cab, 4 cylinder.
Without taking the starter out and bringing it to Toyota (it's in my Dad's truck far away), how can you tell which starter you have, ie. is it the 1.4kw or 2.0kw model (per toyotapartsales.com)?
Thanks!
Old Jan 7, 2008 | 06:15 PM
DeathCougar's Avatar
4wd will be 2.0Kw
Old Jan 7, 2008 | 06:24 PM
bmwpower's Avatar
Originally Posted by DeathCougar
4wd will be 2.0Kw
OK, so his must be the smaller one since it's 2WD. Thanks!
I assume I can't just get the bigger one anyway, probably won't fit, right?
Old Jan 7, 2008 | 06:28 PM
I think they will both fit. The 2rz and 3rz use esentially the same block and trans bellhousing, so the only difference is how much power it puts out. Obviously the 2RZ doesn't need as much power, nor the option to start the truck in gear so they went with the cheaper to built 1.4kw starter.
If you want an "upgrade" step up to the 2.0kw starter. Same mounting, same connections, slightly more power.
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
