96 tacoma 2.7 dies randomly
Old Dec 11, 2014 | 04:48 PM
tackman331's Avatar
I have a Tacoma with the 2.7 that dies randomly like you turned the key off BUT starts right back and runs fine. No CEL or codes. The engine runs fine other then the randomly shutting off.
I have checked the ignition coil which checked good.
Fuel pressure was steady at 46psi at idle and under load
I've put new plugs, wires, and battery no help.
Is there a common problem with these engines that causes this? I'm about at my wits end over this thing.
Old Dec 13, 2014 | 03:07 PM
tackman331's Avatar
Anyone? Any ideas?
Old Dec 21, 2014 | 04:37 AM
Sebastian F7's Avatar
Is it ever hard to start?
Old Dec 22, 2014 | 06:42 AM
tackman331's Avatar
Never.....it starts right. Even when it dies it will start right back up.
Things I've done: fuel filter plugs wires distributor cap rotor button crank sensor coolant sensor and 1 fuel injector. It was way out of spec on resistance.
Old Dec 23, 2014 | 02:10 AM
I was gonna suggest IAC but if its not hard to start I doubt its that.
Charecter1
Nov 6, 2023 10:08 AM
foampile
Dec 18, 2022 01:29 PM
_Nicco_
Aug 28, 2015 07:26 PM
mluz013
Aug 2, 2015 05:00 AM
88runnergomas
Jul 9, 2015 01:12 PM
